while one side is playing and i try to load the next song the volume on the song thats playing gets lower. how do you fix this problem?
geposted Mon 29 Sep 08 @ 9:26 pm
If you are running the system through a mixer, go to config sound
setup, and be sure it is NOT set to headphones.
geposted Tue 30 Sep 08 @ 11:47 am
