there is a problem with the sound. So when I adjust the Bass, MID, Trebble, Crossfade ... there is a noise like "buuuzz " comes with and makes the sound really bad. Does anyone have the same problem ? and how to fix it ?
geposted Thu 02 Oct 08 @ 1:15 pm
I have the same exact issue. The software works great - better than several others I tried - but I when I'm using the crossfader or knobs I get noise.
geposted Sun 05 Oct 08 @ 5:43 pm
Turn Safe mode off if it is checked, or On if it is unchecked, set your performance to Fastest, Latency to Auto.
geposted Sun 05 Oct 08 @ 6:10 pm
Made those changes and it works great now...thanks! :)
geposted Sun 05 Oct 08 @ 9:34 pm
