Once I've downloaded the sound effects I want from the 'download' area...and then I expand the .zip file...how do I "install" them on my mac so CUE recognizes them and I can use the effects? Any help would be appreciated!
geposted Thu 02 Oct 08 @ 10:24 pm
Hi there,
Put the bundle in ur sound effect folder which is located at ur plugins folder of VDJ in ur document;)
Njoy...
Regards;)
Njoy...
Regards;)
geposted Thu 02 Oct 08 @ 10:56 pm
Thanks a ton!
geposted Sat 04 Oct 08 @ 12:54 pm
Hi, I'm having the same problem (FX and skins), but I don't really understand the solution above. Could you explain it a bit more please?!
geposted Mon 06 Oct 08 @ 4:22 am
You have to copy the ".bundle" file in the folder located at "Documents\Virtualdj\plugins\soundeffect" or "Documents\Virtualdj\skins".
Good luck.
Good luck.
geposted Mon 06 Oct 08 @ 1:18 pm
Hi selig87, for skin u may refer to one of my blog for example;)
geposted Thu 09 Oct 08 @ 2:42 pm
there is not bundle file it just show all my effects even the downloaded ones. but they wont show when i open virtual dj :/ i hav windows by the way . is there a diffrent way for windows??
geposted Tue 08 Feb 11 @ 5:04 pm
Sorry, the software that you received with your MixTrack Pro is a free limited edition and does not allow custom skins, effects, etc. to be used or the program configuration options to be changed (Except during the 20 day trial of Pro.)
To be able to use custom skins, effects and much, much more you will need to upgrade to VirtualDJ Professional: http://www.virtualdj.com/buy/index.html
You can also try out Pro features in VirtualDJ v7 Home FREE by going to http://www.virtualdj.com/download/free.html - This software will allow you to test your MIDI controller with it for 10 minutes at a time before reverting back to internal mouse and keyboard control only.
Your VirtualDJ LE entitles you to a discount off the cost of upgrading. To receive this, please go to http://www.virtualdj.com/buy/index.html
geposted Wed 09 Feb 11 @ 10:07 am
ok my question is how to put myy sound effect on pc vjj
geposted Tue 26 Jul 11 @ 9:23 am
im having trouble transferring my sound fx's to the VDJ program , all my sound effects are in a Mp3 audio file , how do i put it onto the VDJ program ,, i also have VDJ home 7 but i dont have a mac i have windows .. any suggestions ?
geposted Sat 01 Oct 11 @ 4:38 pm
I'm having the same issue
geposted Sun 18 Dec 11 @ 3:31 am
Me to i can put new effects in my soundeffects map but wen i open VirtualDJ the effects aren't there
geposted Thu 05 Jan 12 @ 6:35 am
geposted Thu 05 Jan 12 @ 7:53 am
hey when i want to download some new stuff for my free version it says i don't have authority to download it :( plz help
geposted Wed 11 Jan 12 @ 3:03 pm
Please see our FAQ page:
http://www.virtualdj.com/wiki/How%20do%20I%20download%20and%20install%20new%20plugins.html
geposted Thu 12 Jan 12 @ 2:12 pm
Hey
i tried to add new sound effects on my mac..... and i still don't understand it..
is there any way maybe someone can upload a youtube video tutorial on how to do it?
PLz and very appreciated
geposted Wed 18 Jan 12 @ 3:34 am
VirtualDJ LE is limited software and does not support using custom effects. You will need to upgrade to the full VirtualDJ Pro at a discount to be able to use them: http://www.virtualdj.com/buy/index.html
Please see our FAQ pages:
http://www.virtualdj.com/wiki/How%20do%20I%20change%20the%20skin%20or%20use%20plugins%20in%20VirtualDJ%20LE%20or%20Console%20Edition.html
If you are using the 20 day Pro trial in LE, please see:
http://www.virtualdj.com/wiki/Install%20Plugins.html
(NOTE: Any effects that you install during the Pro trial will be unavailable once the trial expires and it reverts back to limited software again.)
geposted Wed 18 Jan 12 @ 4:35 am
hi, i recently got virtual dj. and i see when i got to my desktop and go to virtual dj and click on plugins and soundeffects and there are diffent effects then what i have on the virtual dj program. and i would like to know how to load some new effects that i have downloaded to the software and i cant figure out how too. cause when i search on the search panel and go to virtual dj and plugins and it wont open soundeffects and i know there is a way to load more effects than the ones that were pre-installed. i would like to know how to put different effects on to my effetc scroll nob cause i cant figure out how too. thanks
geposted Tue 24 Jan 12 @ 8:31 pm
geposted Wed 25 Jan 12 @ 4:42 am
