I just recently purchase the pro version and I downloaded and installed the software. I am trying to figure out how I can transfer the analyzed files from video,karaoke, and audio that were already done with the demo to the pro version. I do not want to re analyze all these files and lose all my cue points as well. I appreciate any help you all can give.
geposted Fri 03 Oct 08 @ 12:25 pm
The analyzed date is saved as an .XML file...everything should be the same.
geposted Fri 03 Oct 08 @ 12:32 pm
I found the xml document in the demo folder. I copied and pasted it in version 5 pro folder where I installed it. Restarted program but analyzed files did not show up. Still not working.
geposted Fri 03 Oct 08 @ 12:45 pm
The xml database, should be on the drive where you music/video/karoka files are stored
So if you store them on a external h/d the database should be there with them.
geposted Fri 03 Oct 08 @ 1:12 pm
I copied the xml file to the external drive where my videos and karaoke are located. Still no changes. Does it make it a difference the demo I tried was version 4. Also I have Video files in avi and vob format. The avi works great but the vob is running the CPU meter up to max and plays like a slide show. Almost freezing up. Vobs worked well previously with demo. I have the codecs setup the same as version 4.
geposted Fri 03 Oct 08 @ 2:55 pm
Yes it does. In VirtualDJ version 5, they changed where the location where the database was stored. Sorry mate I may of miss inform you, as I didn't know you had the v4 demo
If I was you I would re-scan all your files, and start a fresh, I don't know if you know but in 5.1 they included a better BPM scan and included a Key detection when it scans.
geposted Fri 03 Oct 08 @ 3:06 pm
Ok I will scan again. Any ideas why vob files aren't working?
geposted Fri 03 Oct 08 @ 3:18 pm
Okay it seems some vob files work fine. When i uncheck hardware acceleration the other vob files that I had issues with play fine but CPU meter increases. Trying to figure out why they played correctly in demo of version 4 but not in version 5.
geposted Fri 03 Oct 08 @ 5:33 pm
