I finally find some time to start looking at my old Vinyl and there are a massive amount of tracks that I need to rip.... Any suggestions on which app is best to use to rip an tag?
TIA
DJKenzo NYC
TIA
DJKenzo NYC
geposted Sun 05 Oct 08 @ 9:17 am
You aren't going to be able to "ripp" a vinyl record. You'll have to record it.
Setup your turntable to your mixer and play your record on normal 33rpm and record the main output on your computer with a recording/editing program such as - cooledit (adobe audition) or cakewalk. Then after recording the song in wave format you can convert it to mp3 (or leave it in wave) and edit the tag.
geposted Sun 05 Oct 08 @ 10:39 am
I had a play about with this, but never really had a proper look at it.
It's free to download and it's pretty good.
geposted Sun 05 Oct 08 @ 10:43 am
