i dont know if i have my rmx configured correctly
i have my headphone plugged in but nothing comes out of the headphone
it used to work when i had my first laptop
now i got a new one and i dont know whats wrong
i am running vista
help
i am running vista
help
geposted Sun 05 Oct 08 @ 11:30 am
In the options of VDJ click "always on" in the headphones tag also check your volume control on the top right hand corner right next to the top headphone jack if that doesnt work then you either have faulty headphones or theres an internal problem with your external controler ( Hercules Rmx ) also try different things with the options to get them to work not every setup is the same so play around with it a bit:)
geposted Sun 05 Oct 08 @ 11:47 am
this may help...
recently i have changed my sound card settings because of a conflict with a plug in i'm using to:- 4.1 and using the cards for the rmx in the drop down window... hope that helps.
geposted Sun 05 Oct 08 @ 2:55 pm
