i just bought a mac and i tryed to hook everything up at my gig and it worked but would not read the timecodes. I know that this was a problem with covectiv with earlyer versions of vdj but though that i would work with the new one. Please let me know a cheap solution if the conectiv will now work (just spent all my money on the macbook pro)
geposted Sun 05 Oct 08 @ 12:37 pm
VDJ with TCVS and TCCDs it's working fine in mac.
Can you register your serial number HERE?
Best regards.
Best regards.
geposted Sun 05 Oct 08 @ 3:07 pm
I've been away for a week or so xonor... Was there an update with timecode? Last I knew, timecode only worked with the RMX and VV interface. Does it now work with Conectiv? Even if it does, to say that timecode is working fine isn't accurate. There are many problems with timecode.
geposted Tue 07 Oct 08 @ 3:12 pm
Hitower, it is still the same atm, only the vv box and the rmx work on timecodes. Read here for my explanation.
Xonor meant right when he said tcv and tccd is working fine.
Regards;)
Regards;)
geposted Tue 07 Oct 08 @ 10:40 pm
