Topic: Extract Title and Interpret for Simplecast
Hi all,
i thought i have a small problem but it looks a little bit bigger.
Following situation.
I use VDJ and would like to transpond the title and interpret to simplecast. reason for this: I use simplecast to broadcast but the radiostation want to have a special "look" for the track indication in winamp or whatever.
The Main problem is, that i can't set the format like this in vdj, because it don't have this feature. (I'm owner of home edition, i know, just small version but enough for me) and also a friend of mine who ownes the Pro version have the same problem. In vdj you are not able to edit the line for title / interpret (only station name), so we are not able to set the "special look".
Is there a way to send the title / interpret of the current song to simplecast?
Simplecast has the possibility for an event lookup e.g. http, serial and so on.
Thsi would be also a fine upgade for vdj which would help some broadcasters if they would have the same interface e.g. shoutcast or simplecast, because we would be more flexible.
Or maybe i'm only to stupid, it is allready existing, and i don't know how to do it.
Best regards
geposted Mon 06 Oct 08 @ 1:50 am
Hallo,
Is er iemand die mij kan vertellen of er een manier is om de titel te sturen / interpreteren van het huidige nummer in SimpleCast en met virtual dj
ik hoop dat iemand dat mij kan vertellen hoe dat zit
Groetjes,
Dj Bender1
Sorry, this forum is for English language messages only.
Please either post your message again in English or use the appropriate language forum at the bottom of https://virtualdj.com/forums to post in your own language.
