Geia sas tsakalia kai kalos sas vrisko !
Loipon pira exthes tin Hercules Rmx na tin doylepso se iMac . Agorasa kai to Virtual Dj 5 alla 177 euro epipleon gia to upgrade. Ola kala leo tora mexri pou pao sto config tou virtual . Meta apo arketes ores kai sindiasmous katafera na doso ixo sta ixeia , oxi omos sta akoustika. An allaza sindiasmo sto config , eperna yxo sta akoustika alla exana ta ixeia. To periergo kai pali einai oti sta akoustika mporousa na akouso oti epeze apo tin pleura pou eixa to fader. To allo deck oti ki an ekana den to akouga ektos ki an allaza to fader.
Sto /System Preferenses/Sound exei tis epiloges Build in Input -- Hercules Rmx USB ---- Hercules Rmx Aggregated , ekei oti ki an syndiasa mia kai to idio itan.
Den anaferome sto section me ta MAC giati den ksero na anafero ola ayta se agglika , elpizo na vroume edo tin lisi !!!
An pali kapoios gnorizei apo Mac , einai texnikos etc. tha ithela na dei to provlima sto spiti kai na plirothei me episkepsi texnikou .
Euxaristo kai ta leme .....
geposted Tue 07 Oct 08 @ 1:55 am
user wrote :
But Yes, I finally sorted it out !!! I contacted the VDJ support, and they simply told me to use another sound configuration, so here is the conf:
You simply have to choose the "4-out card" in the soundcards, and then selects the Hercules RMX in the field "driver 1", and then I select the output channels as "Master: chan 1&2 Headphones : chan 3&4"...
Katebase kai tous teleutaious drivers
geposted Tue 07 Oct 08 @ 3:50 am
Distixos oute kai ayto allakse kati ....... kai update ekana !
geposted Tue 07 Oct 08 @ 7:23 am
