I had some mp3\'s in a folder and I deleted the folder and the files are still showing up when I do searches. Most of the time there are numbers in front of the file name such as
05 Lollipop.
If i drop the file in the queue to be played It gives me an error message. What\'s the best way to get rid of these stray files when I delete folders or move folders from one place to another? i just want to clean my directory of all these stray files with out having to delete one at a time.
Attached is a sample:
05 Lollipop.
geposted Tue 07 Oct 08 @ 11:14 pm
Use the check, clean, fix in the browser tab in the config of vdj;)
geposted Tue 07 Oct 08 @ 11:17 pm
Actually, I've been doing that, prolly once or twice a month and they still dont go away? A year ago, one the techs told be do do it in this order:
clean, check and then Fix.
does it matter?
geposted Wed 08 Oct 08 @ 11:15 pm
If that doesn't work, you can right click on that particular folder or song.
Then click on remove search from database.
geposted Thu 09 Oct 08 @ 5:16 pm
