i can't get the audio to come out stereo left deck + stereo right deck when in midi mode.
when in internal hdd mode, it can output stereo left deck + stereo right deck with out a problem.
can any one help?
thanks,
DJ Shahar
can any one help?
thanks,
DJ Shahar
geposted Tue 07 Oct 08 @ 11:45 pm
Hey did you get your denon hd2500 to work with VDJ if so please let me know how to get this thing going I'm a little frustrated
geposted Fri 24 Oct 08 @ 7:58 pm
download denon asio drivers here: http://denondj.com/plugin.asp?prod=DN-HD2500
connect device via usb.
install all updates and asio drivers.
launch virtual dj
open settings match your settings to this image
DJ Shahar
Los Angeles DJ
launch virtual dj
DJ Shahar
Los Angeles DJ
geposted Mon 03 Nov 08 @ 5:03 pm
did it work?
geposted Tue 04 Nov 08 @ 11:56 am
The denondjforums has tips as well. I enabled Ultra, and also placed the Latency on auto per forum posts and the manual. The sound quality was acceptable, but the right deck started to drift on me after about 90 minutes and both sides hung near 4 hours. I don't think I'll use it as an ASIO device/controller again. Next gig will be my RMX and the HD2500 will remain as a standalone solution.
geposted Mon 22 Dec 08 @ 1:29 am
make sure denon knows about this so they can create a patch for it.
perhaps it's because of the "ultra" unclick that, then try it again.
geposted Mon 22 Dec 08 @ 10:47 am
