Topic: can someone answer my question please?
which file do i need to copy to my new laptop so that the music lists / cue points and playlists come up the same as on my old laptop thanks
shaun
geposted Thu 09 Oct 08 @ 2:03 pm
The xml file from the hard drive with you music should do it.
You need to copy the mp3database.xml file.
Hope this helps
It only works when you have the same root folder and other underneath folders !!!
so what do you do if the new computer has the music on a diffrent drive letter?
just put the file on the hard drive it worked for me
What Version are you using???
