I want to replace my old Maya44 USB card with an internal (PCI) high quality sound card. I have a nice set of headphones and speakers, so I think it is time to upgrade my sound card. I am looking for analog 4in / 4out for VDJ, MIDI capable to work with VDJ and my mixer, and a 1/4" headphone jack would also be nice. Is there a sound card out there that does those three things?
The closest card I found so far is the M-Audio 2496 but I couldn't tell if it has 4in/4out, the pictures show only 2 RCAs. Would this card work for VDJ?
Thanks all.
Thanks all.
geposted Fri 10 Oct 08 @ 1:18 am
I forgot... the card should support XP/Vista, 32-bit and 64-bit flavors.
geposted Fri 10 Oct 08 @ 1:24 am
Viper,
I have a 2496 I use for recording work and its a great sounding card but I would say its not ideal for VDJ. It has 2 ins and 2 outs or you can configure it for 4 outs OR 4 ins but not at the same time, although it does have a digital spdf in/out.
I have to say that I reckon an external card would be better for you, they tend to have more in the way of connections.
Hope this helps.
John
Hope this helps.
John
geposted Fri 10 Oct 08 @ 4:48 am
