2 simple questions NOT related.
1: If i use my turntables with a searto sound card, does that ELIMINATE my "sampler" section? Meaning does the searto sound card have an extra output like the VV card or similar? or will i lose the sampler section using a Searto SL1 card?
2: DDM4000 there Is the mapper tool in downloads. Is this going to give me a default setting that someone created already? like pulling it out of the box and with the XML from the drivers section be able to run the midi immediately? or will i have to map it from scratch? and where does the XML file go specifically what folder? (Double checking)
Thanks crew
Thanks crew
geposted Fri 10 Oct 08 @ 1:48 am
bump
geposted Fri 10 Oct 08 @ 9:57 am
Virtual Vinal has an extra port so you can use the sampler on a seporate channel the serato box doesnt have the extra channel BUT you can set up virtual DJ to use two channels and the sample will come out as if it was on the master channel (i.e. deck A and deck B will play the sample)
geposted Fri 10 Oct 08 @ 10:42 am
Ok that's what i thought.......So instead of 3 channel mixer i would do 2 channel mixer in sound setup and it would incorporate into a or b rite?
geposted Fri 10 Oct 08 @ 11:19 am
DDM4000 question any1?
geposted Fri 10 Oct 08 @ 11:54 am
support?
geposted Sat 11 Oct 08 @ 10:51 am
all the ddm owners and no answer?
geposted Sat 11 Oct 08 @ 9:30 pm
