Ok, guys! I've come to the conclusion that I'm at a total loss of a good program unless I can get a good soundcard... I think.
That Numark VV soundcard is a piece of....
Well you know! What is a better soundcard I can use with VV?
Should I just purchase Virtual DJ and start over?
Last, but not least are there any soundcards with a plugin for your MIC?
I have the VV soundcard and the DJio which serves me no purpose since you can't use both of them at the same time. I need to get rid of the VV soundcard all together... It causes to many freezes and other problems.
Need a good dependable soundcard and willing to spend the money as long as it isn't more expensive than just buying Serato.
Any suggestions?
Any suggestions?
geposted Fri 10 Oct 08 @ 6:26 am
Try the hercules mk2 or hercules remix
geposted Fri 10 Oct 08 @ 9:25 am
You could try the Maya44 USB. From what I gather from the forum, that is the standard for VDJ. Also like the above, the Hercules RMX or MK2 are good.
DJ Digital
DJ Digital
geposted Sat 11 Oct 08 @ 7:37 am
