I have been using Vdj on a dedicated laptop for around 2 years. Recently I have made the mistake of using my laptop as a general pc ( sufing the net etc.) which is something I have always avoided in the past. All my fears have come true as my laptop has now started crashing regularly.
My Laptop is a Toshiba Intel Core 2 / T7200 / 2.00 Ghz / 1 Gb.
It is not overheating (which has been a problem in the past)
Does anybody have any advice to restore stability - I am a working Dj but have now lost confidence in the laptop as it has crashed 3 times in the last 2 days.
geposted Fri 10 Oct 08 @ 2:22 pm
Any information about the crash - for example is it an OS crash, a VDJ crash, or a 3rd party application crash?
geposted Fri 10 Oct 08 @ 8:51 pm
The crashes are not vdj related - they are happening when surfing the net.
I am thinking of clearing down the HD and reinstalling Windows Xp Pro - what do you think?
geposted Sat 11 Oct 08 @ 3:04 am
First thing I'd check is wether any windows updates have been installed unknowingly.....this has happened to me before and a simple rollback sorted a problem I had.
Worth checking I reckon......
Lee
Lee
geposted Sat 11 Oct 08 @ 7:08 am
Edited
geposted Sun 12 Oct 08 @ 3:49 am
OK, so what is the actual crash? Is it a blue screen? An application crashing? We really would need more information ;)
geposted Sun 12 Oct 08 @ 11:29 am
The laptop just freezes.
geposted Mon 13 Oct 08 @ 2:40 pm
Man, that could be as simple as a virus too! They will act that way sometimes due to that. Why don't you try running a virus scan after clean anything that should'nt be there.......
Then, delete all history, recycle bin, etc....Due a disc clean and defrag your PC, restart and try it again before you go any further it's a quick solution before you get to complicated, just try it out and see what happens :)
geposted Mon 13 Oct 08 @ 8:47 pm
I don't understand how surfing the net can destabilise your laptop? I use this same laptop for DJing, Gaming, Surfing, Chatting, Schoolwork... Everything!
I never had a single crash in the 2 years i've been using VDJ....
geposted Tue 14 Oct 08 @ 3:24 am
