Hi guys...
how i can connect my laptop (which have instaled virtual dj) with mixer??? I mean which cable i should use for this???
thanks a lot...
thanks a lot...
geposted Sat 11 Oct 08 @ 6:45 am
If you are using a mixer you need an external sound card.
Like the M-Audio Conectiv, Maya, etc.
http://www.zzounds.com/item--MDOCONECTIV
geposted Sun 12 Oct 08 @ 10:19 am
it's best to have an external sound card, if however you don't just now you may want to try this...
basically if you cant follow the clip
go to config
soundsetup
outputs > external mixer
soundcards > mono seperated
output channels give you white lead/left channel red lead/right channel to your mixer
you will have to use a y splitter for each channel to get dual inputs into mixing desk
which of course will only give you mono sound output
geposted Mon 13 Oct 08 @ 3:44 am
