after trying RMX for 2 weeks, I gave up, I sold it on EBAY for $60 less then i bought it.
Button and sliders keep dissapearing from the screen, does not support UTF-8 encoding on Apple or PC, pitch bend F&^% up beatmatching, etc etc..
I'm gonna buy Numark NS7 with serato itch when it comes out, for now, just will use scratch live.
check out the videos
http://www.youtube.com/watch?v=9LUxOyjNql4&feature=related
http://www.youtube.com/watch?v=sYSP078uBuM&feature=related
geposted Sat 11 Oct 08 @ 7:06 pm
ok thanks for sharing. But do be advised your could not get one controller or software working but hundreds of people have. so instead of figuring out what the problem is you plan on buying a controller that cost 3 times as much with software you have never used. Well I will just be looking on ebay if you get frustrated and plan to sell that off fo cheap. :)
btw you were using the Limited Eddition. I would of tried upgrading first. that would of been a cheaper route. but you didnt wait to ask me did you :)
geposted Sun 12 Oct 08 @ 11:00 am
ns7
yuuuck
get separate components. if something breaks, you have options. if something on the ns7 breaks, you have to put the whole thing in the shop. if you have a backup that works, I would say go for it.
and yeah, start with a full version of whatever software you decide to use...
yuuuck
geposted Sun 12 Oct 08 @ 12:30 pm
