I'm using shared/built-in sound card on my desktop compute, can virtual dj software separate the headset cue from the output sound? I just wand to make it sure before buying the software. I've tried the trial version but I was not able to see the option or configuration for it.
geposted Sun 12 Oct 08 @ 1:40 pm
hope this is what your looking for...
basically if you cant follow the clip
go to config
soundsetup
outputs > external mixer
soundcards > mono seperated
output channels give you white lead/left channel red lead/right channel to your mixer
you will have to use a y splitter for each channel to get dual inputs into mixing desk
which of course will only give you mono sound output
geposted Mon 13 Oct 08 @ 3:37 am
