Is there a MIDI config. XML file fro the RMX? is so, where?
I want to edit some buttons on the controller but im having a hard time with a custom xml file.
geposted Mon 13 Oct 08 @ 10:26 pm
bump...
hoping someone will have an answer...
geposted Fri 17 Oct 08 @ 5:36 pm
No. There are 2 ways you can use the RMX - the hardcoded configuration through Native support. Or you have to map the whole console through the MIDI.
geposted Sat 18 Oct 08 @ 10:36 am
thats what ive suspected all along... thanks anyways
geposted Sat 18 Oct 08 @ 11:16 am
How would you map the whole thing through midi?
geposted Mon 16 Feb 09 @ 9:54 pm
Which buttons/faders are you trying to modify the functions for?
If it is the 6+6 buttons, you may find my thread of some help.
Let me know if you need anything.
https://virtualdj.com/forums/104623/Hardware_Technical_Support/Hercules_DJ_Steel_functions__VDJ_5_2_1_pro.html
Matt.
Matt.
geposted Mon 16 Feb 09 @ 11:14 pm
