hey all, i've downloaded the trial version of the softwear and i'm enjoying using it but i have a question, i own a dj console mp3, is it possible to use this control with the new version of softwear at all? i have looked at the control option on the program but the mp3 control does not appear to be on the list, only the hercules mk2 control.
cheers
add
cheers
add
geposted Tue 14 Oct 08 @ 11:00 am
tell me if this is a stupid question but can i not use the control because it's a trial version of the softwear?
cheers
add
cheers
add
geposted Fri 17 Oct 08 @ 8:50 am
All of the Hercules DJ consoles (MK1, MK2, MP3, RMX & Steel) are supported in VirtualDJ Professional.
The consoles should also work with the trial version of VirtualDJ Pro too.
Please go to CONFIG -> Remote Control, click on the Hercules DJ Console icon and choose Activate
geposted Fri 17 Oct 08 @ 12:11 pm
i've tried that but nothing happened, any other ideas??
geposted Sat 18 Oct 08 @ 3:39 am
