My Hercules MK2 arrived and I have been having trouble setting it up with virtual dj.
I dont know if the settings I have are correct..
The headphones side is coming out through the speakers as well as the other deck.
I cant seem to have just one deck in the headphones and deck A playing the tune whilst I get ready for a mix.
I have tried flicking the switches on the head phone switch but that seems to change how the music comes out through the HIFI.
So confused!
So confused!
geposted Wed 15 Oct 08 @ 12:11 pm
Sorted!!!
:D:D:D
:D:D:D
geposted Wed 15 Oct 08 @ 5:42 pm
How did you fix it?
geposted Fri 17 Oct 08 @ 2:03 pm
i am having the same problem. how did you fix it. only deck A is playing through the headphones.
geposted Fri 24 Oct 08 @ 7:03 am
'sound setup' tab --> outputs --> headphones
then play with the 'output channels' drop-down below.
I havent got a mk2 so dnt know exactly but it's along those lines
geposted Fri 24 Oct 08 @ 9:04 am
how to switch between headfones and speakers?
geposted Sun 29 Mar 09 @ 8:32 am
