I´m looking for a PC videocard for karaoke and video files. I really appreciate your inputs for a reliable videocard. What kind should I buy? Thanks a lot for all your help.
geposted Thu 16 Oct 08 @ 12:42 am
We need a little more info about your system, ie. Vista or XP also give us some system specs.
geposted Thu 16 Oct 08 @ 2:26 am
It is a Windows XP Desktop, Service Pack2, Intel Processor 2160 @ 1.80 GHz, 1MB RAM, 160 GB HDD.
geposted Thu 16 Oct 08 @ 6:44 pm
i would say that the ati 4850 is the best to get for the $$ http://www.newegg.com/Product/Product.aspx?Item=N82E16814103069
frist of tell alit more about your board
do you have pci express 2.0?
geposted Fri 17 Oct 08 @ 11:03 pm
quote]
[/quote]
I do have PCI Express... I have no idea if its 2.0
[/quote]
geposted Sun 19 Oct 08 @ 9:16 am
I run the 4850 in my touchscreen setup, I would try it in XP, I dont know how well it will work as it is made for Vista. You might also want to google "4850 fan fix" if you get this card and speed up the fan as this baby runs HHOOTTTTT.
I run Vista and love this card.
geposted Sun 19 Oct 08 @ 5:35 pm
How can I find out what kind of PCI Express Port do I have?
geposted Tue 21 Oct 08 @ 9:21 am
You need to find detailed specifications on your system board, who made your PC?
However, if all you are needing is a new video card for playing videos, the 4850 is probably overkill. Radeon X1050 and up should work fine for video, you should be able to find a X1550 reasonably priced.
geposted Tue 21 Oct 08 @ 9:36 am
