hi all
see alot of peeps are using these are they any good? also can i still use my soundblaster 24 live 5.1 and is it vista compatible.
just noticed the mk2 aswell is that any good as that a better price range for me lol and is that vista comp and can i still use my sound blaster
many thanks
pinhead1000
many thanks
pinhead1000
geposted Thu 16 Oct 08 @ 1:23 am
you won't need to use the soundblaster if you purchase the rmx, and yes the rmx is vista friendly.
geposted Thu 16 Oct 08 @ 5:34 am
cheers for the reply tayla
how do i connect it to the pc then as i only have a bog standard sound card in the pc with the usual blue green pink?
many thanks
pinhead1000
many thanks
pinhead1000
geposted Thu 16 Oct 08 @ 10:55 am
simple usb cable and your good to go, set up will probably need tweeking but thats par for the course, then its simple enough to connect to a mixer or direct to an amp.
geposted Thu 16 Oct 08 @ 12:33 pm
cheers tayla
do i just plug my computer speakers into the back of the hercules then and set the hercules as the card in vdj is that right? as i dont have an amp and speakers i want it all running on my pc and pc speakers
many thanks
pinhead1000
many thanks
pinhead1000
geposted Thu 16 Oct 08 @ 5:14 pm
outputs on the rmx back are rca or 1/4 jack out line/phono, if you haven't a suitable connection to the rca just use ear plug out on lappy
geposted Thu 16 Oct 08 @ 5:29 pm
You should buy the Rmx not the Mk2. I have been working on a Rmx that I bought for four months and it works well. it has a much better layout than the Mk2 and draws it's power from the usb to so you don't need an outside power source. Worth the extra money.
geposted Mon 20 Oct 08 @ 2:40 pm
yeah i think im gonna get the rmx as the mk2 looks a bit placky and tacky and the jog wheels are way to close to the fader for my liking id end up catchin the jog wheel all the time
geposted Mon 20 Oct 08 @ 3:42 pm
