I am thinking about getting into some basic uplighting. I was wondering if anyone can tell what I will need, ect. I see all different types of LED par cans with different numbers of leds ect. I see wireless universal controllers. I want to be able to have a master/slave setting, keep them on one color or have them all change at the same time. I dont want to spend alot, just want to get a couple to try. Any suggestions would be great....
geposted Thu 16 Oct 08 @ 8:08 pm
Nobody can tell you how many, because nobody works in the same rooms as you.
But a good place to start would be getting a decent DMX controller, some chauvet
colosplash jrs, color pallette, american dj punch, etc. and learning how to program dmx lighting.
It's not hard, just time consuming.
geposted Fri 17 Oct 08 @ 4:45 am
I started with 10 american dj led par 64 PRO. I quickly saw that 10 was not enough and bought 6 more and am getting ready to buy 4 more for a total of 20.
The amount i have can decently cover most rooms but honestly more is better. Other than that a decent DMX controller either hardware or software and tons of cable is all you need. I control my lights wuth compuware pro from elation and i purchased all my cables from here
http://www.speakerrepair.com/Merchant2/merchant.mvc?Screen=PROD&Product_Code=37-250x10&Category_Code=25ft-mic-cables
I know they are not " true DMX cables " But they work just fine.
Good luck, Alex
Good luck, Alex
geposted Fri 17 Oct 08 @ 11:11 am
The American Dj LED are too expensive for me at the moment. I need to get somethign cheaper to try it.
geposted Fri 17 Oct 08 @ 12:06 pm
From what i hear chauvet also makes a decent led par can. I believe it's called the rain.
geposted Fri 17 Oct 08 @ 1:40 pm
I've been buying stuff from these folks for seven years, they have some prett decent stuff for the price.
http://www.cheaplights.com/cart/page15.html
geposted Fri 17 Oct 08 @ 1:54 pm
