So the problem is, that one of my decks bpm isnt constant. An example tracks bpm is 128, but when I but it on that deck, then the bpm counter goes crasy, the bpm run 127,8 127,5 127,9 128..... and so on and so on. Its quite hard to beatmatch, when the track goes allways off. I got both signals 100%, but that decks signal sometimes goes down to 93% and then again 100%, but thats only sometimes.
So where is the problem? Why isnt the speed constant?
geposted Fri 17 Oct 08 @ 12:22 pm
In the Timecode config, there is a option called "Pitch sensitivity"
Try raising it up to 1500 for example. That should solve you little problem out mate.
geposted Fri 17 Oct 08 @ 12:27 pm
What version are u using?
geposted Fri 17 Oct 08 @ 12:50 pm
Virtual dj 5.1
geposted Sat 18 Oct 08 @ 8:57 am
