Topic: question about renaming files
Hey everybody,
Is there a program that, while zipping files down, specifically karaoke files, will take the mp3 info and rename the zip file with that info? or a program that will rename the cdg info with the info from the "attached" mp3?
geposted Fri 17 Oct 08 @ 2:35 pm
E rock...This one will be a stong test for your needs..try "Flash Renamer" ( http://www.bestoemsoftware.net/sale-Flash_Renamer_6.0.htm ) play with it a lil and see if you can manipulate the filenames to your needs, Then zip the new files up with a seperate zipper software. Should be possible...If it does the trick ...post back with your results.... Good Luck with those Karaoke screamers....I call them SCARE-E-O-KE
