Forum: Old versions
Topic: imac, leopard & VDJ
I just wanted to let anyone that wants to know that the issues that I had with the Imac (Leopard) and VDJ might actually be resolved by using the original virtual skin for PC. If you go to config then skins and it says virtual DJ: Mac full! I used that skin and the new one that just came out and had issues. Tonight I used the original skin. Not the one that said for mac. Just the one that said Virtual DJ:Full and I didn't have so much as 1 issue! Worked flawlessly tonight. So I am hoping that will be the fix.
Just wanted to hopefully help someone out that might have been dealing with the issues that i have been dealing with. Such as not being able to type in the search feature out of nowhere & the beach ball spinning forever after trying to click on a task.
geposted Sat 18 Oct 08 @ 1:48 am
