I am trying to install a maya44 in vista, i do not see the option to configure the card at all after the install.
I am trying to use it with a VCI-100. Does the vista install give you the same option as windows XP?
I sure hope I can figure this out because I really love vista overall.
Thanks
Thanks
geposted Sat 18 Oct 08 @ 9:42 pm
that is correct.
you can see in the setup dir an setupmain.ini file with following sections
DEFAULT_TITLE=Maya44 USB ASIO driver
TARGET_DIR=usb-audio.deMaya44
ASIODLL=Maya44.dll
ASIODLL_X64=Maya44_X64.dll
SHOW_BITMAP=1
FORCE_UNPLUG_2K=1
FORCE_UNPLUG_XP=1
DISABLE_EULA=0
ALLOW_KEY=0
ALLOW_MULTIPLE_DEVICES=0
STEP_DELAY=500
ROOTDRIVER=Maya44.inf
GUID_CLASS=0x1df47772 0x8554 0x4ec0 0x9c 0x05 0xc6 0x36 0x63 0x77 0xac 0xf9
After Installation you can find under \Windows\usb-audio.deMaya44 a setup dir.
ASIODLL=Maya44.dll
SHOW_BITMAP=1
FORCE_UNPLUG_2K=1
FORCE_UNPLUG_XP=1
DISABLE_EULA=0
ALLOW_KEY=0
STEP_DELAY=500
geposted Sun 19 Oct 08 @ 2:54 pm
