I have been using the Hercules sound Card as it is convienient to have everything in one unit. Is this a decent sound card or should I be using a different sound card to improve my sound? How would it improve?
Thanks
Thanks
geposted Sun 19 Oct 08 @ 11:23 am
The herc mk2 and the rmx is a mid-range quality soundcard. If can be decent enough for the sound quality with proper setting but if u using timecodes n do some scratching it best to invest better soundcard such as the audio8 etc.
geposted Sun 19 Oct 08 @ 11:29 am
well hercules won't be much help for software higher than vdj 3.4, so forget tech support
sound card.. i say it's awesome. it's been working for me since i first started with vdj.
controller buttons die out after long usage. really hard to press play now.
if you're a starter, then i would definitely recommend hercules. you can easily pay it off with 1 or 2 dj events.
never touched rmx, but i hear lots of great stuff from it. the wheel is said to have improved.
that's my 2 cents.
that's my 2 cents.
geposted Sun 19 Oct 08 @ 3:51 pm
Hercules rmx sound quality breaks up after the gains are turned up past half way and the sound isn't that loud, you need powerful amps with this controller.
geposted Sun 19 Oct 08 @ 4:48 pm
I only use the Hercules to fade the video and the audio with virtual DJ. I turned off most of the other buttons and use a Numark controller for play etc..
I have noticed that I have to turn up the gains on my mixer more then my CD players when using the Hercules sound card. However nothing is distorted unless I increases the Hercules EQ or turned the gain up in Virtual using for an individual song.
geposted Sun 19 Oct 08 @ 10:49 pm
For that unchecked safe mode in config if u using the herc as soundcard too;)
geposted Mon 20 Oct 08 @ 5:33 am
Where is "safe Mode" in the configuration?
geposted Mon 20 Oct 08 @ 9:46 am
in the performance tab, under the performance slider n beside the overclock;)
geposted Mon 20 Oct 08 @ 9:36 pm
Thanks for the help. I found it.....but what does this do when I uncheck safe mode?
geposted Tue 21 Oct 08 @ 7:08 am
What is overclock and what advantage would I have by having it ticked? Should I un-tick it?
Dell 1520
2.2 Dual Core
4GB Ram
256MB Video Ram
320GB HD
Vista 32 Bit Premium
VDJ/Latest Version
Dell 1520
2.2 Dual Core
4GB Ram
256MB Video Ram
320GB HD
VDJ/Latest Version
geposted Mon 24 Nov 08 @ 4:04 pm
