I have only just upgraded to the latest version of vdj from 4.something. Installed all fine. Put my music on and click on a folder to display the songs in the browser but they are displayed as unknown artist and just a track number no song or artist name like before. All the file names are Artist - Title. Please help!
geposted Mon 20 Oct 08 @ 5:33 am
to the right of the search bar there is a small bullseye open that up and you will be able to select which fields you want to display in your browser, at the bottom of this drop down window you can select in which order they will appear. in the one furthest to the right you can choose which fields it will show i.e. covers, music, video or karaoke.
geposted Mon 20 Oct 08 @ 6:30 am
I am having the same problem with Atomix. What can i do?
geposted Mon 20 Oct 08 @ 9:31 pm
Check your id tags for each track to make sure they are titled correctly. This happened with me and i had to correct every single track , it takes forever , but once you have them all done you dont need to change them again. You need to title your track and artist seperatly rather than both together...
geposted Tue 21 Oct 08 @ 4:21 am
Tag & Rename would have had that done for you easily ;)
If you don't want to use tags, you can always disable tag support.
geposted Tue 21 Oct 08 @ 5:36 am
