Hello all DJS! I'm looking for a CD cover making software that will read ID3 tags from my mp3s and allow me to insert the "comments" field from the tags. Could anyone help me out? Any ideas which software can do this?
geposted Mon 20 Oct 08 @ 10:39 pm
Isnt there anyone who can help? I need a reply soon because i have to burn a lot of cds for a gig to which i cannot take my pc.
Thanks!
Thanks!
geposted Tue 21 Oct 08 @ 10:20 pm
This will do it!
http://www.cdrlabel.com/
geposted Wed 22 Oct 08 @ 12:45 am
you can try this, http://www.medea.co.uk/pressit/pressit_download.htm or try nero, better still why not by an all in one printer similar to epsons does everything for you from the cd itself to labelling, they are quite inexpensive nowadays.
geposted Wed 22 Oct 08 @ 3:44 am
ok thanks a lot for the links! Will check them out ASAP!!
geposted Wed 22 Oct 08 @ 10:15 pm
I use Corel paint shop x2 which is cheap and Photoshop, which is way more expensive. Weird eh :( One has options the other doesn't hehe.
IMO though, the price of a software does not matter, or what you USE. It is how much knowledge you have about a product. Heck, you could do a cover in MS Paint :) Don't know what kind of quality you would get though. Some of the artwork on You-Tube has been phenomenal. I am sure there is a person that is awesome at using that piece of software. Or do a google search on "Gimp" which is a good free program from what I read about it and has a big following.
geposted Wed 22 Oct 08 @ 11:43 pm
Hi Djjae! I use Photoshop too since i'm a photographer also. :)
But if you read my first post, i needed a cd cover software that lets me insert the comment field from ID tags of mp3s. Because i store my BPM and Key information on the comment field of the tags. Hope you understand. I used to use Nero Cover designer, but i had to manually type the bpm and key after the track name whihc got tedious while burning 40 -50 cds a day.
geposted Fri 24 Oct 08 @ 7:12 am
