Since the old site isnt available anymore. Where can i find plugins, skins, effects for Atomix? Thanks!
geposted Tue 21 Oct 08 @ 7:53 am
Yes that has also crossed my mind where can one obtain these?
geposted Tue 21 Oct 08 @ 3:57 pm
Anyone?
geposted Sat 25 Oct 08 @ 8:01 am
Seems a little strange to sell a product as including plug ins but not to make them available any more :(
Would it be possible to zip up a selection and publish those on this website?
geposted Sat 25 Oct 08 @ 3:57 pm
I found some effects/plugins on peer to peer but it's not all of them. I hope they do something about it!
geposted Sun 26 Oct 08 @ 5:32 am
I have been using Atomix for many years now and still love it. It has been working great with my XP computer and I find it very user friendly.
Recently I installed it on my Vista computer. For some reason, I'm not sure why, but all the songs show double. One of them will play and the other won't. This has happened before on my XP, but I just went into my C drive, opened up Atomix under program files, and deleted the mp3 database. Problem was solved.
Now with Vista, it won't allow me to do this. Also, it doesn't give me the option of the history feature. Why is this? Am I missing something? What can I do to fix this problem ?
I can't keep having all my songs show double. It's too confusing. Please let me know how to fix this. Thank you.
geposted Tue 28 Oct 08 @ 11:53 pm
Try going into config> browser> look into the drive with the music folder > Check > clean > ( fix )... This should get rid of most duplicates.
Now the question is do you have a music on multiple drives. If so, right click on main music folder of the drive you want to hide > remove from search.
Now for your history> go into config > browser > on the left hand side> choose - show history
geposted Wed 29 Oct 08 @ 2:21 am
@fatkatzdj
He is talking about Atomix Mp3, it does not have that options.
@djlovelace
As I know, Atomix Mp3 is not updated with new versions since 2003, so it is understandable that is not working on Vista which is launched in 2007. You can still use it on XP.
@djlovelace
geposted Wed 29 Oct 08 @ 4:52 am
my bad!!!
geposted Wed 29 Oct 08 @ 7:20 am
