Hey guys
So I'm noticing that while not all of my MP3s are the same bit rate, at times it sounds as if the volume is fluctuating.
Is there any way to make it so all levels balance out?
Of course I raise and decrease volume with changes in track volume but is there a way to make it less noticeable?
Currently using Virtual DJ on a PC.
Thanks!!
Guy Ruben
Thanks!!
Guy Ruben
geposted Wed 22 Oct 08 @ 3:39 pm
Google Search MP3Gain....I used it once..it works pretty well for volume control. As to the bit rate there is little you can do except lower the high quality ones...which I would not recommend....
geposted Wed 22 Oct 08 @ 4:08 pm
the ideal for DJ use is 320Kbps and i wouldnt bother with anything less than 192Kbps just keep it in mind for future ripping/buying
geposted Thu 23 Oct 08 @ 9:27 am
