i just bought the i cue form a buddy..*he cant mix* lol.. it works great..
however the gain numbers on the screen are never steady..the
volumes fluxes while the tunes are playing causing me to always adjust them
can anyone help with this..as the gain is solid when i use my maya44 and tcds
geposted Wed 22 Oct 08 @ 3:47 pm
Config, options, gains, auto....see if that helps....
geposted Wed 22 Oct 08 @ 4:09 pm
its still moving...but its not as bad..just have to monitor the numbers...
geposted Wed 22 Oct 08 @ 5:06 pm
disable the auto gain in Virtual Dj (Configuration/options/auto gain) and if you use Itunes uncheck (Edit/Preferences/Sound check).
I hate the volume changes in the middle of the songs, but this require that you adjust the levels when you are playing, like when you are using CD's.
geposted Thu 23 Oct 08 @ 10:41 am
