Hi everybody!
I added to my gig equipment a PlayStation 2 with all the SingStar DVD´s, to get a battle Karaoke on the partýs that they ask.
The thing is than I´m thinking to improve the connexion between everything, becouse now I had to switch de Video of the computer and the PlayStation with a remote control...
The thing is that I has a Dazzle DVC150 that is an analog USB video recorder...So I´m thinking if it would be possible to show the video of this device on the Webcam plugin of VirtualDJ...so with this you can switch the analog video out only selecting the plugin on virtualDJ...
What do you think? It could work with enough resolution?(All te conections are component video, so maximun output of the PlayStation is DVD resolution)
Thank you a lot!
Thank you a lot!
geposted Fri 24 Oct 08 @ 11:01 am
Hi, yeah it should be possible, i think the best thing to do would be just plug it in and see, the quality might be good enough. You would get slightly better quality if you coulld use an s-video connector i think.
geposted Fri 24 Oct 08 @ 1:22 pm
