Hi guys I need some advice. I have a vci-100 with a maya 44. I can only hear one side at a time in the headphones?
Any clue?
Any clue?
geposted Fri 24 Oct 08 @ 8:33 pm
Hi, what settings are you using in the "soundcard" tab of VDJ?
Also, are you using the little headphone jack on the end of the maya, or using some sort of other mixer with it?
geposted Sat 25 Oct 08 @ 1:57 am
I am using a 4 channel mixer and also using the mixer's headphone jack.
geposted Sat 25 Oct 08 @ 7:44 am
I can only hear the side that the fader is switched to.
geposted Sat 25 Oct 08 @ 9:04 am
Go into Config -> Options tab and set the Crossfader setting to Disabled
geposted Sat 25 Oct 08 @ 11:58 am
I tried that both both sides plays through at the same time now with no controll of a cross-fader. This is weird.
geposted Sat 25 Oct 08 @ 12:07 pm
You are using an external mixer correct?
And the headphone jack on the mixer?
So all your crossfading is done there, not at the VCI.
Now, if you setup the Outputs (Config -> Soundcard setup tab) as Headphones and not External mixer. Then you can have 1 channel on your mixer be your MAINs from the MAYA (Ch 1&2) and then another channel on the mixer be your PFL-Headphone channel (Ch 3&4 on the MAYA). Then you can use the VCI to control both audio and video crossfade and the PFL in VDJ will toggle what gets sent to the Headphones channel.
geposted Sat 25 Oct 08 @ 12:38 pm
So what is the best hook-up for the vci-100. I want to use the fader on the vci-100 not the mixer.
Thanks
Thanks
geposted Sat 25 Oct 08 @ 12:42 pm
Thanks for all of your help, but that is not working neither. Do I hook the hedphones into the Maya 44?
geposted Sat 25 Oct 08 @ 4:57 pm
man I am slow...........go it thanks alot.
geposted Sat 25 Oct 08 @ 8:15 pm
