hi all
just got my new rmx and the cross fade dont do anything when i move it over it moves in vdj but it dont cut sound at all plus im getting no sound from deck 2 at all my m8 has vdj 5.2 and i cant even get my rmx to work at all with that can any 1 help me out with setting it up for both please as i want to use at my mates later
many thanks
pinhead1000
many thanks
pinhead1000
geposted Sat 25 Oct 08 @ 4:31 am
you can register your rmx in "modify my profile" if you like... just use the serial on the reverse of the cd cover that you got, it will then allow you to a limited amount of goodies.
geposted Sat 25 Oct 08 @ 10:01 am
cheers tayla
can you tell me how to set it up properly m8 ive been trying since 9am this morning and cant get the crossfade to do anything
i have the rmx to pc via usb
my pc speakers into the jack plug in output 2 using the green plug that normally goes in the back of the pc with an adaptor on the end
in vdj my sound options are
inputs =none
outputs = headphones
soundcard = rmx
ive disabled the fader in vdj but i get nothing from the fader on my rmx it moves in vdj as i move it but dont change from deck a to deck b
hope you can make sense of that and please please help me out im rippin my hair out now
many thanks
pinhead1000
inputs =none
soundcard = rmx
many thanks
pinhead1000
geposted Sat 25 Oct 08 @ 10:11 am
all sorted now ;)
cheers jimmy b ;)
cheers jimmy b ;)
geposted Sat 25 Oct 08 @ 1:24 pm
