Does anyone know how to use the RMX soundcard output for windows sound in general?
It used to work with the BCD3000 without me really changing anything.
Cheers
Cheers
geposted Sun 26 Oct 08 @ 12:25 pm
Hello looshus,
By default, Windows XP should take the last sound card you have connected to your PC as default USB sound card: if you
- unplug/replug the DJ Console Rmx to your PC,
- and wait until the cross on the DJ logo on right of the task bar to disappear,
- then you call DJ Console Rmx control panel and set WDM as audio mode,
then DJ Console Rmx should be the default sound card for Windows.
If DJ Console Rmx is not your default sound card in Windows Media Player, you can change it easily:
- run Windows Media Player,
- click on Tools,
- go to Options
- go to Mobile Devices
- click on Speakers Properties
- and select as audio playback device: "DirectSound: Hercules DJ Console RMX"
- click on Tools,
- go to Options
geposted Mon 27 Oct 08 @ 12:09 pm
Thanks for your help, I think the problem was I was in ASIO mode
geposted Mon 27 Oct 08 @ 1:21 pm
I have the same problem with vista x64, So I had to setup a dual boot on my system to run both XP x86 and Vista x64, with XP just for the dj console. I sent Behringer a email telling them my story about the driver not working with vista x64. He said that if enough complaints come in then it would get fixed faster. SO PLEASE GOTO THE SITE AND CONTACT THEM ABOUT YOUR PROBLEM!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! DJ MT from VA
geposted Wed 05 Nov 08 @ 5:39 pm
