When I'm playing videos I set the transition I want (Fade for example), after every single transition it randomly changes to another.
I just want it to stay on whatever I've set it to.
I'm not using the random video transition effect, I don't even have it downloaded.
Thanks
Ross
Thanks
Ross
geposted Sun 26 Oct 08 @ 1:45 pm
That's strange. Are you using a controller with a jpboggis custom mapper? I know that they have inbuilt random transitions. If you do then you can turn them off in the settings. If not, I'm not sure what could be causing it.
geposted Sun 26 Oct 08 @ 5:20 pm
You're right, good memory, totally forgot about that feature in the mapper.
Been using it for ages but only recently started doing video in in V5. Was still using 4.3 on my Gig Rig until last week.
Cheers.
Ross
Cheers.
Ross
geposted Sun 26 Oct 08 @ 6:48 pm
