HP Pavilion Laptop with Intel® Core™2 Duo Processor T5550.....$629.99
SPECS:
Processor Brand.....Intel®
Processor.....Intel® Core™2 Duo Mobile
Processor Speed.....1.8GHz
Display Type.....WXGA high-definition widescreen LCD with BrightView technology (1280 x 800)
Screen Size 15.4"
System Bus 667MHz
Cache Memory 2MB on die Level 2
System Memory (RAM) 3GB
Hard Drive Type SATA (5400 rpm)
Hard Drive Size 250GB
Optical Drive Double-layer DVD±RW/CD-RW
Graphics Intel® Graphics Media Accelerator X3100
Video Memory Up to 358MB
S-Video Outputs 1
PCMCIA Slots 1 ExpressCard/34/54
USB 2.0 Ports 3
IEEE 1394 FireWire Ports 1
Operating System Windows Vista Home Premium with SP1
VERSUS:
HP Pavilion Laptop with Intel® Core™2 Duo Processor T5800......$799.99
SPECS:
Processor Brand Intel®
Processor Intel® Core™2 Duo Mobile
Processor Speed 2.0GHz
Display Type WXGA high-definition widescreen with HP BrightView technology (1280 x 800)
Screen Size 14.1"
System Bus 800MHz
Cache Memory 2MB on die level 2
System Memory (RAM) 4GB
Hard Drive Type Serial ATA (5400 rpm)
Graphics Intel® Graphics Media Accelerator 45000MHD
Video Memory Up to 1759MB total available
S-Video Outputs none
PCMCIA Slots 1 ExpressCard/54
USB 2.0 Ports 2
IEEE 1394 FireWire Ports none
Operating System Windows Vista Home Premium 64-bit with SP1
which is better? im just going to b usin sound with virtual dj.
SPECS:
Screen Size 15.4"
System Bus 667MHz
S-Video Outputs 1
USB 2.0 Ports 3
VERSUS:
SPECS:
Screen Size 14.1"
System Bus 800MHz
USB 2.0 Ports 2
geposted Sun 26 Oct 08 @ 4:15 pm
The second one offcourse but it costs more. You can use cheaper one for audio but none of this is good for video use.
geposted Sun 26 Oct 08 @ 5:04 pm
at what price ranges are video laptops...any you recommend? I was planning on just doing audio but if i could get a laptop for video for a couple more money I would just get that instead.
geposted Sun 26 Oct 08 @ 8:23 pm
For video I'd say CPU @ 2.6 or higher, at least 3gb RAM and a graphic card
in 300$ + price range (I don't know which ones are preferenced for VDj,
but I'm sure someone will point out).
geposted Mon 27 Oct 08 @ 2:28 am
The weak point of those laptops are in integrated video card in chipset, so no video use with them. For that money you can take some MSI model (2 years warranty) with some ATI 2600 card with its own memory, at least 256MB ddr3 is recommended.
geposted Mon 27 Oct 08 @ 4:32 am
Thanks...I think I'm going to stay with sound only for now........so how about the first laptop? Good? Bad? For the specs and price? (for sound ONLY) Is there really a HUGE difference between both that would want me to buy the most expensive one instead?
SPECS OF FIRST LAPTOP...
SPECS:
Screen Size 15.4"
System Bus 667MHz
S-Video Outputs 1
USB 2.0 Ports 3
BTW I will be using it with a Hercules RMX & MK2(backup)
SPECS:
Screen Size 15.4"
System Bus 667MHz
S-Video Outputs 1
USB 2.0 Ports 3
geposted Tue 28 Oct 08 @ 8:59 pm
The first one has a bigger screen and more usb ports,
having more usb ports are always handy, but then you could also just get a usbhub.
geposted Tue 28 Oct 08 @ 11:06 pm
SPECS:
Screen Size 15.4"
System Bus 667MHz
S-Video Outputs 1
USB 2.0 Ports 3
VERSUS:
SPECS:
Screen Size 14.1"
System Bus 800MHz
USB 2.0 Ports 2
You should even post this read the specs. but i would choose the HP Pavilion Laptop with Intel® Core™2 Duo Processor T5800......$799.99
SPECS:
Screen Size 15.4"
System Bus 667MHz
S-Video Outputs 1
USB 2.0 Ports 3
VERSUS:
SPECS:
Screen Size 14.1"
System Bus 800MHz
USB 2.0 Ports 2
geposted Wed 29 Oct 08 @ 8:34 am
