Trying to record my live video mix but it keeps giving me a recording error saying video codec not found. Any info would be great.
geposted Mon 27 Oct 08 @ 6:36 pm
Hi, there are ways round that my downloading the ms-mpg4 codec off the net, but so far I haven't heard of anybody who's made it run smoothly. When I record the video is always jerky.
What I've done in the past is to use a second PC for recording (one with a TV card with an s-video input), or you could try the FRAPS software if you don't have a second PC, or probably easiest to just buy a DVD recorder and do it that way.
geposted Mon 27 Oct 08 @ 6:58 pm
i had d same problem all i did was download registry tool n choose wat codec u want.
http://www.virtualdj.com/addons/2170/Registry_Tool.html
geposted Wed 29 Oct 08 @ 8:20 am
hello and welcome to awaken the forum vdj
I put the two explanations of recording (mp3 and video) we never know, tests made with VDJ 5.2.1
for recording and MP3
if you do not see the file lame_enc.dll in My Documents \ VirtualDJ \ Plugin
Downloads>> HERE <<lame_enc.dll file and place it in \ My Documents \ VirtualDJ \ Plugin
for video
1) download xvidvfw.dll v1.1.3 fixed by djcel>> HERE <<
Simply copy this dll djcel and place it in C: \ Windows \ System32 and overwrites the previous one.
2) download K-Lite Codec Pack>> HERE <<
3) check the updated DirectX, and your graphics card
4) launch vdj you click record Movie -> config ... You look down in size if there is well written or divx xvid
if you find that writing [MPG4] erased it and you write and divx xvid OK then close and restart vdj vdj and start your video
Second phase
If the video does not start or video and audio effects does not go in the configuration vdj -> tab video
and make sure [use acceleration Harward] is well check if it is not checked, check OK then close and restart vdj vdj
geposted Fri 31 Oct 08 @ 4:31 pm
Hi,
Thanks a bunch. Is there a way to get a better resolution?
The AVI file is just 320x240. If I project this to a screen on play on a 52" inch TV, it will look blurry...
File details (audio and sonique visualization video)
Audio: MPEG Audio Layer 3 44100Hz stereo 256Kbps [Audio]
Video: XVID 320x240 25.00fps [00) Video Stream]
Audio: MPEG Audio Layer 3 44100Hz stereo 262Kbps [Stream 01]
Regards
Nick
for video
Second phase
Regards
Nick
for video
Second phase
geposted Tue 11 Nov 08 @ 12:39 pm
I seem to be having problems like this as well.
I have downloaded all of the files listed, and have selected the MPEG codec in the registry tool, and can record with no codec problems. When I go to the config screen and select the file to save, the only file type option I have is avi, and the recorded video is VERY choppy. I have tried to put divx or xvid in the codec type (but nether of these show up in the registry tool) and that's where i have the codec problems.
Am I doing something wrong?
Please help!!!
THanks...
WAyne
Please help!!!
THanks...
WAyne
geposted Tue 11 Nov 08 @ 9:52 pm
same here this is a real issue and should be looked at. asap.
geposted Fri 05 Dec 08 @ 12:04 am
It pice of not working crap............ whay they call it vdj i tried everything didn't work its usless....
geposted Wed 06 Oct 10 @ 10:11 pm
All you have to do is, where it asks for the "Codec" leave it blank. VDJ will make it an avi by default.
Hope that helps
Huey
Hope that helps
Huey
geposted Wed 06 Oct 10 @ 10:26 pm
Yes but why avi? Is there an alternative? It's not a file format that I am very fond of for the obvious reasons.
geposted Sat 30 Oct 10 @ 6:37 pm
AVI (Audio Video Interleave) is not a codec but a multimedia container format.
geposted Sun 31 Oct 10 @ 8:13 am
heyy... im tryin to record my video mixes but after they are recorded an i'm playin it, the video is always sticking an the audio is never in timing with the video.... what can i do to get clean video mixes???
geposted Mon 10 Oct 11 @ 1:29 am
I have tried all the various codecs to record video internally with VirtualDJ. The results were not great and found the best was still a little blurry and the sound ran out of sync over time.
What I use now is the Fraps external program. Works great and can produce useable quality.
If you go onto the first page of my website and scroll down, there is a short demo that was recorded with Fraps.
http://www.vjles.com
geposted Mon 10 Oct 11 @ 5:13 am
my virtual dj on config.. brings up only WAV and MP3 how can i change it to codecs ? on recording on the left only has Record File, Save Cd, & broadcast but i don't have Record Video
geposted Sun 13 Nov 11 @ 1:12 pm
you probably have it on @RECORD AUDIO@....there's more selections on the left to pick from.
In this order: Record Audio, Burn CD, Broadcast, Record Video.
geposted Mon 14 Nov 11 @ 3:51 pm
I use an additional pc, dazzle usb capturing device & nero software to make mixed videos.
geposted Thu 24 Nov 11 @ 5:18 pm
when i record video on virtual dj the video goes out of time with the audio .. does anyone know how to fix this issue please?
geposted Sat 16 Feb 13 @ 7:06 am
http://www.bandicam.com/
That's is all you need...........Enjoy.
geposted Sat 16 Feb 13 @ 1:29 pm
For all who have problem mixing videos and the audio not syn with the video i use to have that problem but i found a software that correct all that problem
geposted Tue 06 May 14 @ 10:42 pm
