I can't seem to find the Atomix MP3 skins, etc. downloads anywhere . . . does anyone know where they went?
geposted Tue 28 Oct 08 @ 9:09 am
Contact support for this;)
geposted Tue 28 Oct 08 @ 11:58 am
Yes, ask a question here:
https://virtualdj.com/contact/
geposted Tue 28 Oct 08 @ 12:45 pm
This is coming back soon ... stay tuned..
geposted Tue 28 Oct 08 @ 6:37 pm
I have been using Atomix for many years now and still love it.
It has been working great with my XP computer and I find it very user friendly.
Recently I installed it on my Vista computer. For some reason, I'm not sure why, but all the songs show double. One of them will play and the other won't.
This has happened before on my XP, but I just went into my C drive, opened up Atomix under program files, and deleted the mp3 database. Problem was solved.
Now with Vista, it won't allow me to do this. Also, it doesn't give me the option of the history feature. Why is this? Am I missing something? What can I do to fix this problem ? I can't keep having all my songs show double. It's too confusing. Please let me know how to fix this.
Thank you.
Thank you.
geposted Tue 28 Oct 08 @ 9:38 pm
djlovelace - don't make multiple posts on the same topic please.
As to your issue - do a search for the mp3database.txt file and make sure you search Hidden folders and files. You should end up with 2 files. Now here is the 'backwards' part. The one you actually want to delete is the one in the AtomixMP3 folder. The other one is the one that Windows (Vista) is actually keeping up to date. But do this - delete the one in the AtomixMP3 folder - run AtomixMP3 - does everything function correctly? IF not, then restore that file from the recycle bin and go delete the other file.
geposted Wed 29 Oct 08 @ 6:41 am
ok
geposted Wed 29 Oct 08 @ 5:49 pm
subedarkid wrote :
can some one let me use their account to download stuff
Hmmmm.... not a good place to ask that question.
geposted Wed 29 Oct 08 @ 6:15 pm
