hey for all u ppl who'd rather to create a realtime drumkit sampler-
1.get any drum samples you can find on the net(i just import mine from fruityloops)
2.then reprogram the samples 1-12 to the num pad(its easier this way) as 0-9,/,*
3.then import the drum samples you want into the specific sample slots.
4.then drum away.
i know many of ya'll have probably done this already...but for those who haven't...try it , it's fun an you can create some real cool re-mixes an beats if you can create and have a sense of rythym.
4.then drum away.
geposted Tue 01 Feb 05 @ 2:52 pm
I know it sounds easy for you to reprogram the samples but I am not able to do it.
Can give please explain me how to reprogram the samples to the num pad?
geposted Tue 15 Dec 09 @ 10:11 am
