basically what is the difference... i think i want a 1TB drive so whats the difference between something like this http://www.amazon.com/LaCie-301304U-External-Design-Poulton/dp/B0010YWPZ8/ref=sr_1_26?ie=UTF8&s=electronics&qid=1225285541&sr=8-26 which is a very reasonable price... and something like this http://www.amazon.com/1TB-USB-External-Hard-Drive/dp/B001BZS0EQ/ref=sr_1_46?ie=UTF8&s=sporting-goods&qid=1225285613&sr=8-46 which is more expesive ... is there something i should know about performance or anything with these externals? thanks
geposted Wed 29 Oct 08 @ 8:07 am
Do you really need 1 tb. i have a 500 gig western digital hd which i have over a millions songs on and it still aint full. but i would chose the LaCie Hard Disk 301304U 1 TB USB 2.0 External Hard Drive.
geposted Wed 29 Oct 08 @ 8:28 am
yeah technically they both have the same cach space and the same speed so get the cheaper one! LaCie Hard Disk 301304U 1 TB USB 2.0
geposted Wed 29 Oct 08 @ 8:53 am
i have just brought the samsung 1tb spin point from ebuyer.com. Good reviews on this one and the price is good.
geposted Wed 29 Oct 08 @ 9:46 am
I would go with Seagate, while LaCie makes a good drive, Seagate usually offers a 5 year warranty on most of their products. If you shop around you should be able to find the 1TB Seagate for about the same price as the LaCie.
geposted Wed 29 Oct 08 @ 11:08 am
go with a eSata, usb is 480mbps and the eSata is 1.5 gps data moving that much faster and faster read write rates but one thing to remember is not to get a expantion card that is esata to pci as this will be really slow make sure that the cable coming out of the esata conection goes into a sata port on the mobo
thank you and have a nice day\night
geposted Wed 29 Oct 08 @ 8:34 pm
