Ive been trying to get my TCVs to work flawlessly, i've been doing a lot of reading on the forums, tried many many things, DPC Latency Checker, disabled many many things and still have the problem, Stopped running many processes, had it down to 37 processes, and a CPU Usage of 23%, tried running my RMX in Asio & WDM, still skips & drags...
Here is where I am, Uninstalled the latest version of VDJ and reinstalled v5.0.7, running in Asio mode, and v4 of the tcv config option, so far its been about 40 minutes with no hiccups or drags...
THEORY: I posted about this in the Tech Support forum, the BPM analyzer is constantly trying to analyses the track, hence the constant change in BPMs (althought usually +/- .2 or .3) but it seems that the engine is trying very hard to match up songs and its impossible, as it adjusts it DRAGS to the other dot on the CGB, since it cannot match up the highs and lows on the audio waves it SKIPS a beat and starts all over again, I specially noticed this when the Beat Lock was ON.
It also seems to be worse on real intrument music (like Salsa, Samba) that in House & Dance...
will report shortly, with updates...
geposted Wed 29 Oct 08 @ 7:19 pm
hi rasza, probably the problem could be in the stylus or the capsule, I have similar problem and I disconect the capsule and clean the head shell contacts of my TTs.
Also in the Time codes config, check if the signal from the TCVs degrades or changes too much past some minutes.
By
By
geposted Wed 29 Oct 08 @ 9:48 pm
had a good run with it successfully, i figured i should restart my laptop to see if it would change and sure enough it changed, im back to square one, trying to sort out skips and drags...
FYI: Using a Hercules RMX, 2 TTXs, and this laptop (removed all the BS junk that comes with a new computer) http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00880243&lc=en&dlc=en&cc=ca&lang=en&product=3379129#
geposted Wed 29 Oct 08 @ 10:18 pm
Welcome to the club.
Constant pitch movement, and poor TCV signal. In small words, virtualdj time code vinyl's sucks, is the only thing that sucks on virtualdj.
geposted Mon 24 Nov 08 @ 10:54 pm
If you don't want to see pitch movement put "Pitch Sensitivity" at 1000 -
I have always 100% time coded signal with a cheap ortofon DjE only 11 months a year everyday with NO FREE DAYS , so , please , stop to cry .
Vdj Time Coded can be better ...all we know here , but don't say TCV sucks when 99% are working PERFECT - If TCV works for me must work for you .
geposted Mon 24 Nov 08 @ 11:17 pm
