Hi I purchased the Hercules RMX days ago and just installed the VDJ LE edition. I clicked on the 20 day trial of Pro and it worked fine. When I came back to the computer later and opened VDJ, it said my 20 day trial was already used. Can anyone help why this happened? or how to completely uninstall the program so that I can re-enter my serial number and all that
I tried App Zapper, but that didnt seem to help
Thanks
Thanks
geposted Thu 30 Oct 08 @ 8:35 am
Contact support for this..thanks,
geposted Thu 30 Oct 08 @ 12:01 pm
I did and no one has been able to help. I found all the vdj files and put them in the trash and emptied them. When I went to reinstall, it never asked for the serial number and went right back to the same thing where my 20 day trial said it was already used. Anyone have this problem? or know how to really uninstall this and its registry
geposted Thu 30 Oct 08 @ 1:38 pm
Thanks that did work and allow me to re-enter the serial number, but the trial still wont work properly. I click for the 20 day trial and it doesnt work.
geposted Fri 31 Oct 08 @ 7:10 am
Hmm, when i read abt it again, i just realised that there are no mac trial atm. That why it don't work as it should. In order to use the trial, u have to use vdj on bootcamp and the trial should work there. Sorry:(
But i strongly urge u to purchase pro n u will see it is worth it. U can use on solely on mac osx;)
Regards.
Regards.
geposted Fri 31 Oct 08 @ 2:32 pm
I just got a mixtrack pro and loaded the LE software. When I went to use the trial it sayd my 20 days are up. I had the hercules rmx i tried about a year ago so I am thinking that has something to do with it.. Also before i clicked on the trial I could see my whole itunes library but now just 135 songs. I am looking to upgrade but think the softwares are fighting eack other. have unistalled all VDJ but still get the ATPR request for keychain.
Any thoughts?
thanks
Any thoughts?
thanks
geposted Sun 21 Nov 10 @ 11:32 am
