i am running a toshiba 2 GHz laptop with adm core duo, 3.3 GB ram,
turntables: http://www.numark.com/ttx
mixer: http://www.numark.com/ppd01
hercules rmx
and the virtual dj pro 5.2
can somebody help me setting up the timecodes or direct me to a site or a guide thats out there that will help me the setup please! its urgent,
i posted this under hardware support and i have got no response, so i am putting it on here, HOPING SOMEBODY HELPS ME
THANKS SO MUCH! I WILL REALLY APPRWECIATE IT!
hercules rmx
geposted Thu 30 Oct 08 @ 1:10 pm
I'm not sure how to set it up with an external mixer, but... If I were you i'd consider using the rmx as the mixer. It'll have pretty much all the functions of the numark mixer plus buttons for VDJ effects. Plug your tables into the inputs on the rmx (1 and 2). In the VDJ config panel, set inputs to timecode, sound card to rmx. Click the Timecode Config button and play your TC vinyl. I think there's an auto config once you get to that screen. That should do it.
geposted Thu 30 Oct 08 @ 2:26 pm
thanks a lot man, i appreciate it...
geposted Thu 30 Oct 08 @ 2:27 pm
Never mind, I missed that part where you mentioned having Pro 5.2
Good luck.
geposted Thu 30 Oct 08 @ 3:52 pm
what bout it?
geposted Thu 30 Oct 08 @ 4:30 pm
The first you need:
https://virtualdj.com/homepage/xonor/blogs/3289/Modo_ASIO_para_todas_las_Hercules_RMX_y_MK2.html
Before this, you have to config the tcvs
You can see the config for TCVs here, it's for mac, but the config it's the same.
https://virtualdj.com/homepage/xonor/blogs/3288/VIRTUAL_DJ___RMX___TCVS_(Mac_Version)_TCCDs_too.html
geposted Thu 30 Oct 08 @ 7:52 pm
thanks man, u have no idea how much that helps...
geposted Thu 30 Oct 08 @ 7:58 pm
It was nothing.
We are here to help.
geposted Fri 31 Oct 08 @ 8:44 am
i might bother you a lil bit if i have problems...;-P
geposted Fri 31 Oct 08 @ 8:48 am
I don't mind.
Add me as a friend in your home page if you want.
Best regards from Spain.
geposted Fri 31 Oct 08 @ 8:51 am
