hey,
follow this procedure to cause vdj to freeze
notes
please fix asap.
good luck
thanks,
DJ Shahar
Los Angeles Wedding DJ
- use any skin
- use any sound card
- use any settings you want.. it really doesn't matter
- enable jp boggis mapper for hc4500
- move anywhere in the song to the middle
- set cue 99 with knob
- keep pressing knob to return to cue 99 while scratching with jog disc
- cpu meter will keep going up unitl it reaches max and then it will freeze
- at this point you can not do anything other than click on config > disable hc4500; enable hc4500.
- repeat steps to crash again.
notes
- when hc4500 sends/receives data LINK is highlighted on hc4500
- after freeze, LINK turns on and doesn't turn off.
- any control used on unit will cause LINK to blink and then stay turned on.
please fix asap.
good luck
thanks,
DJ Shahar
geposted Fri 31 Oct 08 @ 10:30 pm
I've just tried doing this and experience no problems. The CPU usage does increase while doing this, but not beyond 50% on a 2Ghz single core CPU. I have tried using both the current v1.2 mapper and the new v1.3 beta mapper. I am using VDJ v5.2.1 on Windows XP.
Please ensure that you have the latest firmware and drivers installed for the HC4500 - The older drivers had a MIDI bug that would cause VDJ to freeze. To download, please go to http://www.denondj.com/plugin.asp?prod=DN-HC4500
geposted Sat 01 Nov 08 @ 1:19 pm
