hello everyone.
i have just bought a behringer djx700 and i was wondering if i could use it with virtualdj and my hercules mk2 in one setup, if possible, how?
geposted Sun 02 Nov 08 @ 11:58 am
That mixer can't control nothing of VDJ, you can only use it as an external mixer.
Anyway, you can use the embeded effects.
An advice, you can use two outputs from the hercules, and mix in two separated channels, like you have two cd players.
geposted Sun 02 Nov 08 @ 12:12 pm
i just use the inputs in the hercules with ma technics.
so i can only use the effects on the behringer and nothing else? not even the volume?
geposted Sun 02 Nov 08 @ 12:30 pm
is ther a way u could use TCV with my behringer? can virtual dj still intereact with it somehow with assitance from the hercules mk2?
geposted Sun 02 Nov 08 @ 12:35 pm
Of course you can control the volume.
What i wish to told you it's that you can't control nothing of VDJ, because there's no midi or usb conection betwen the DXJ and the computer.
The TCVs or TCCDs has to be directly conected to your MK2, and the MK2 to your mixer.
geposted Sun 02 Nov 08 @ 5:36 pm
so if i connect my mixer to the my mk2, ill be able to control the volume of virtual dj using the behringer?
geposted Mon 03 Nov 08 @ 3:36 pm
But u need to have the VDJ pro to be able to use with external as the djc edition can't permit u that.
Regards;)
Regards;)
geposted Mon 03 Nov 08 @ 3:37 pm
oh well, ill buy pro first then thanx.
but.. how would i connect all this up in the future? i want to know how to connect a mk2 to my behringer, alowing me to control virtual djs interface with the behringer
geposted Mon 03 Nov 08 @ 3:47 pm
It is simple my friend;)
From the output of ur mk2, insert it to line in of channel 1 and channel 2 etc. From config choose external mixer. If u using timescode vinyl and turntable, insert that to the input at the mk2.
The behringer will work as external mixer n WILL NOT control the software interface...only ur mk2 capable doing that. Of course u can change the volume but the knob etc in the software will not follow as it is not midi mixer. But using ur mk2 when u turn the knob, it will.
Using the eq on the external is better than using on the internal vdj software.
Hope it is clear;)
Hope it is clear;)
geposted Mon 03 Nov 08 @ 3:55 pm
thats alot clearer, thanx alot pal,
God i soo cant wait to buy this software!
geposted Thu 06 Nov 08 @ 6:46 am
geposted Thu 06 Nov 08 @ 6:54 am
do you no if i can connect djx 700 to my mac book and use the mixer to operate the decks & sound , and stuff ?
cheers
cheers
geposted Fri 28 Dec 12 @ 6:40 pm
